跳转到主内容
Repair and detailed information for the GE Profile Refrigerator PWE23KSD****, a compact, built-in, bottom-mounted freezer fridge with French door access, introduced in 2014. This page covers information for model numbers matching the pattern PWE23KSD****.
How to put GE in diagnostic mode
This bottom freezer GE I bought in 2015. How can I put it in diagnostic mode? Model# is PWE23KSDESS.
Freezer is working, but was too cold at -16 degrees. Fresh food compartment not cooling, was about 65 degrees. I did some disassembling and found coils just on top of freezer but behind lower part of fresh food compartment are covered with ice. Also found a fan there. I suspect that fan is not working. Blades spin freely, but when I close doors on fridge I don't hear it kick on. There is another smaller fan that sits right nearcthe water reservoir . I think its to cool the water. I did not see thatone turn on either. I do see the fan in freezer turning. It turns even when I have freezer door pulled open. I'm curious if that is normal operating since for fresh food compartment, fan is supposed to turn off when you open doors. So I'm not sure if freezer fan is supposed to run when freezer is open .
Now about 12 hours after clearing ice, freezer at 0 degrees, and fresh food at 63.
So I want to put it in diagnostic mode to see if maybe other issues like defroster, bi metal, etc.. is messed up. The plug on the fresh food fan is those 6 prong ones. Not sure how to test? Please any help greatly appreciate.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Replacing the refridgerator evaporator fan has fixed the problem. Couple things to mention in this experience: testing the fan with a multimeter for ohms or voltage as suggested by many just dis not work for me. I did as instructed with multimeter and got dame results with old fan and new fan. Kind of lead me to think that it was not the problem since new fan was giving me same results. But I slapped the new fan in and came right on . So unless i was testing fan the wrong way, seems test results are unreliable. Change the fan any way. Thanks
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Hi @fh1973
Here's the mini manual for the refrigerator. It shows how to enter the diagnostics and what the error codes mean.
Hopefully this will help you to find out what's wrong.
这个答案有帮助吗?
得分 2
5条评论:
Thank you so much. My unit does not have water, crushed, cube options. It has freezer, refridgerator, door alarm, lock controls, reset filter, and ice maker buttons , all on one of the doors.
完成的
@fh1973
All I can say is that I was going on the information from the following suppliers who both say that the mini manual is GE 31-51901, which I linked above
supplier 1, supplier 2
Hopefully the wiring diagram will still help you.
GE used to place the mini manual in a plastic sleeve either behind the toe plate (if the fridge had one) or in the compressor area somewhere. Don't know if they still do but maybe worth a look anyway
完成的
Replacing the refrigerator fan fixed the problem. Thank you
完成的
@fh1973
It may not have been the fan motor that was the problem. There is also a speed sensor circuit in the fan that is connected back to the control board. Maybe it was faulty
完成的
A week later, and still good . Seems problem fixed.
完成的
添加一条评论
添加你的答案
Frank 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 24
过去 30 天: 147
总计 11,967
