跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
Why can't I restore my phone?
I replaced the battery in my phone and get the picture below. I hooked my phone to iTunes and tried to do a restore. I got a error saying that this phone can't be restored because of unknown error. Could it be because I didn't have consumer cellular unlock the phone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Why have you asked the same question you asked 14 hours ago and got the answer to?
完成的
Different question, tried what I was told and now another issue.
完成的
添加一条评论
2个答案
最有帮助的答案
I have never seen this happen after a battery install on the 8 series. There is nothing around the battery connector which might have been nudged that will cause this issue. Since the phone is not showing an apple logo and is going straight to recovery or DFU mode usually means there is a communication problem between the CPU and the NAND. The only thing I could think that would cause this is if you used heat to remove the screen and or battery. Also it doesn’t matter what lock status the phone is in as it will still be able to restore. If you have a microscope, multimeter and schematics you could check some of the circuits to make sure none are open if not you will need to send the phone to a reputable repairer.
这个答案有帮助吗?
得分 3
2条评论:
You need to heat the screen to remove it or you risk breaking it.
完成的
@strongbow Thanks Nigel. I should have put more heat than necessary.
完成的
添加一条评论
You have to put the phone into dfu mode for iTunes to restore it. Google how to put it into dfu and follow the instructions.
这个答案有帮助吗?
得分 0
3条评论:
I did that, but I get that error after it starts the the restore.
完成的
Try another cable, also another USB port or even another computer if you can. Also make sure iTunes is updated. It might even be a problem with the new battery or, you damaged something removing the old battery.
完成的
@rbthud what error are you getting. Does it give you a number with the error message?
完成的
添加一条评论
添加你的答案
Robert Hudspeth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 133
