跳转到主内容
The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
91 个问题 查看全部
Why won't my GameCube turn on with a memory card in slot a?
Up until yesterday my GameCube was working fine while playing a game with a Memory Card in Slot A. Today I went to play a different game, switching out the memory cards and the orange GameCube light flashes on briefly before turning off while the fan keeps going. However, if I take out the memory card it works fine...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Have you tried a different memory card and having the same issue? Sometimes the memory card can cause a short and turn off the device.
这个答案有帮助吗?
得分 0
2条评论:
I've tried both Memory cards I have and they're both having the same issue, even the one I was using yesterday. The slot causing a short would definitely make sense though. Do you know how to fix this?
完成的
Not directly sorry. But i would take out the motherboard from the console and inspect and see if i can see anything suspicious or try replaying the motherboard.
Hopefully someone els have a better answer :(
完成的
添加一条评论
添加你的答案
Sam Wannell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 173
