跳转到主内容
Repair and further information for the GE Profile Refrigerator PYE22KSK****, a 2016 built-in, French door refrigerator with a bottom-mounted freezer and automatic defrost system. This page covers information for model numbers matching the pattern PYE22KSK****.
Why is my fridge light on?
My fridge light won’t turn off. This is a pic of the part inside the fridge that turns on as well as what it looks like when the fridge is closed.
https://imgur.com/a/JHH1FdL
How do I turn it off?
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Generally there is a door switch that controls whether the light is on or not, but without knowing the model number of your refrigerator we can't say exactly where that switch will be located; they're frequently found near the top of the door frame, but can be anywhere along the top, edge or bottom of the door frame.
Once you locate the door switch, you should be able to manually press it and see if the light goes off when it's pressed. If it doesn't, chances are the door switch has failed and needs to be replaced. That would be my first approach, but testing it with a multimeter will confirm whether it's working or not. It's also possible there's an issue with the wiring to the switch and/or the control system, but the switch is the first place to look at.
这个答案有帮助吗?
得分 1
2条评论:
The model number is PYE22KSKBSS. The light turns on when the door sensor is pressed instead of off.
完成的
Having this same issue! Did you ever figure this out?!
完成的
添加一条评论
添加你的答案
Victor Stein 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 28
总计 645
