Device is on 'emergency calls only' after factory reset
I tried to upgrade the Magisk, but that failed and it left me no other choice to factory reset it. After that, my phone is now unable to recognize the sim card (It does show sim card unlock code prompt when you insert the sim) and the service won't change from 'emergency calls only' mode. IMEI code on the back is nowhere to found in the system. (Both sim slots IMEI shows different numbers) Prior to reset everything was working fine, but now I am stuck with this problem. What should I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
