跳转到主内容
加入维修社区 - 创建账户
Apple's fifth-generation smartwatch, with optional cellular connectivity, released September 20, 2019.
Apple Watch display lcd
I try to repair an Apple Watch serie 5 , but some but something go wrong when I try to attach the lcd display to connector , there is a solution for know if is the lcd screen broken or the connector ?
https://drive.google.com/file/d/1Y-9mF3X...
https://drive.google.com/file/d/1eZnVucF...
https://drive.google.com/file/d/1eawCLGr...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Adding pictures of the back of the screen ribbons and the connectors on the board would help.
完成的
Thanks Nigel, i have added the photo
完成的
添加一条评论
1个答案
Sadly your OLED display is damaged! It looks like you had a hard time getting it off as the displays edge looks damaged, but the worse is the damaged connector on the backside. It also looks like the ribbon cables are a bit tattered as well.
In any case you need a new display.
这个答案有帮助吗?
得分 0
3条评论:
Can you recommend a site where to take the display with advantageous prices?
完成的
I had tried to separate the touch display from the lcd display…
But if you tell me this, I order new display.
完成的
@Leonardo Barbieri - You’ll need the full display assembly which includes the crystal, touch & OLED display. These can’t be gotten separately.
Sorry I don’t have any parts source anymore to recommend.
完成的
添加一条评论
添加你的答案
Leonardo Barbieri 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 176
