跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 个问题 查看全部
2010 MacBook Pro does not chime and has no display on startup.
I was using my laptop as normally a few days ago. I had the display at low brightness and the volume turned off (not sure if this has something to do with it).
I let the computer run out of battery. When I charged it overnight, the indicator on the side said it was full but when I went to power it on, nothing showed on the display and I could not hear a chime. I did hear the fans spin and the disk drive made a noise but that was it.
I also have the disk partitioned so sometimes when it restarts it boots into a blank screen that says something like "no bootable drive found" but normally I can avoid that by pressing option and selecting my drive. Is there a common fix for this?
I have tried plugging it into an external display but there was no output. I have also let it run out completely from the fans spinning and charged it again, but it still has not made a difference.
I did change the battery, but that was in September and it has been working fine since then.
Fix: I left my computer alone for a week or so and I tried resetting the pram. I pressed the power button while hold command option p and r and I heard the chimes. After the display booted back on, I realized it was booting into my second partition of windows, which is extremely glitchy. Once I tried to boot it into mac, it worked fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Let’s give this a try, disconnect the battery following this guide 2010年中期MacBook Pro 15寸 Unibody 电池更换 stopping at Step 4. Then with nothing connected press and hold the power button for a good 15 secs. Carefully reconnect the battery and try starting the system again. Did that work?
Update (12/26/2022)
Sadly, this looks like something deeper in the logic board.
这个答案有帮助吗?
得分 0
2条评论:
I will try it after Christmas, thanks.
完成的
Hi @danj I tried what you suggested but the issue is still there. When I press the power button, the light on the front of the computer turns on, but turns off again once I release it. Could it be the gpu or another large issue or could it be software related?
完成的
添加一条评论
添加你的答案
SamuraiSammy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 23
总计 151
