Leon Shirk @leonsk
声誉积分: 1
发帖于: 2022年12月23日
I took my phone out into sub zero temp. now its completely dead and will not charge even tho it has warmed for hours.
这是一个好问题吗?
3条评论:
Did it also get wet?
由 Robin Groot 完成的 2022年12月23日
@Robin Groot Not except my camera lens on the phone is broken so there was some condensation under the glass
由 Leon Shirk 完成的 2022年12月23日
It might have damaged the insides you could lay it in some rice to try and dry it out but it could have also been something else because you let it freeze outside the battery does not like temps lower then 0.
Aiden Zell @ip7geek24
声誉积分: 33
3
your problem may be
1 the battery has over drained due to Cold temperature and is no longer able to hold charge, or
2 water condensation somehow got inside of the phone itself and caused damage
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 117
由 Robin Groot 完成的
由 Leon Shirk 完成的
由 Robin Groot 完成的
