跳转到主内容
Logic board replacement. Is it possible due to T2 chip?
Hello,
I'm looking to move a logic board from one mac to another due to one having a swollen battery and the other being a much better spec. Will the Mac be useable without AST 2 System config?
I'm aware about bringing the Touch ID over with it but it will have a new top case and possible display.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi
As far as I know aslong as you have the same shape Board that is from the same year your top case should work
Your screen could work but I cannot confirm that it will work fully as apple does like to remove features or brick the device when people replace things
If the board is a different shape it won’t work as the different models have different heatsinks and different numbers of ports
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 0
2条评论:
Thanks for the info! The board is the same size so should be fine. I'm more wondering if diagnostics or configs from AST2 need to be run on logic board migration as the logic board will be connected to a different (but exact same) display, trackpad, keyboard and battery.
Any ideas? Thanks!
完成的
@slat
Hmmm not too sure about that one
The AST2 might be needed if you want True Tone and Touch ID paired but it might be worth going ahead and seeing what happens
完成的
添加一条评论
添加你的答案
Jack 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 19
总计 365
