跳转到主内容
The OnePlus 7 is an Android smartphone from OnePlus. It was announced in May 2019.
16 个问题 查看全部
New Battery not fixing poor battery life
My phones battery would start draining really quickly at the 30% mark (1%) every 30 seconds or so. I downloaded one of the battery health apps and it was at 60% health
I replaced the battery with a new one from ifixit but the issue still remains.
Is there any way to fix it or is the phone done for?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
Does it do this when using the phone in safe mode or disabling mobile data?
If not it may be downloaded apps i.e. apps that you downloaded and installed not that came pre-installed with the phone, that may be downloading in the background unbeknownst to you and this is depleting the battery faster.
Also try turning off the WiFi and/or BT if they are turned on as when on they are constantly looking for new networks, other BT device etc this may be causing the battery to drain faster than it normally would. You can check in WiFi Preferences and BT Connection preferences to see what is enabled that maybe you don't want
这个答案有帮助吗?
得分 0
1条评论:
Yes I have tried this and wiped the phone also. Unfortunately it is still the same. Thank you for your help though
完成的
添加一条评论
添加你的答案
Kitt Walcot 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 46
