跳转到主内容
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 个问题 查看全部
My IPad 2 is stuck in DFU mode. I don’t want to lose my data.
My iPad is in great condition and it worked perfectly before I lost it about 5 years ago. As the title says it’s stuck in DFU mode. I read that you can reinstall the OS to fix everything but iMazing gets stuck on “Waiting for NAND”. Is there anything I can do to fix this or can I at least somehow see the Apple ID that’s was used on the iPad?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
download 3utool from here http://www.3u.com/ onto your computer, connect the ipad and it will give you the option the kick it out off dfu mode
这个答案有帮助吗?
得分 1
3条评论:
It gives you the option to ‘exit recovery’ I have never seen the option anywhere to exit dfu. Could always press and hold power and the home button for 20 - 30 seconds until the apple logo appears. Also the battery is probably past it.
完成的
It does show an option to exit DFU, but when I click on it it says to hold home and power buttons until the apple logo shows, but it never shows up. I know the screen works because the apple logo shows up when I tried to reinstall the OS.
完成的
It shows you how to exit dfu not 3u tools does it for you. It sounds to me that the battery has had it and has dropped below a charge level it cannot recover from after sitting for five years. I’d forget the dfu issue and start by fitting a new battery then try it.
完成的
添加一条评论
添加你的答案
Alejandro 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 257
