跳转到主内容
Install windows 10 with boot camp failure
My macbook gets stop code: WHEA UNCORRECTABLE ERROR during windows install. Then restarts then get message your computer restarted unexpectedly windows install cannot continue please restart computer and try reinstalling windows.
This gets in a loop. Im using bootcamp and ive tried deleting windows partition within bootcamp and reinstalling several times fire vault is off and ive confrimed that via terminal. Any ideas on this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
At this point you need to run Internet recovery to wipe the drive and re-install macOS. Then you’ll need to upgrade it to the version you are currently running or newer if that’s possible.
Be aware you will loose everything! If you have an external drive which was setup as a bootable drive with your user account credentials you should be able to backup your stuff first.
Then try again, make sure you have the correct Windows version for the version of BootCamp you are using.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aaron Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 205
