跳转到主内容
Repair and disassembly information for Samsung's flagship S21 Ultra Android smartphone, released in January of 2021.Also known as the Samsung SM-G998U1
20 个问题 查看全部
Screen flashing/battery not charging
My phone got wet. It was fine and I immediately shut it off and it shutdown as normal and I dried it out. Go to cut it back on and when the battery had power it would show the charger connector symbol when it was connected and it would only boot to the OS install mode. But if connected to the charger the phone will stay on and the battery will die while connected. So I replaced all the ribbons and the battery and the ear piece section of the phone and samething. When the battery had power it would pull up the charging screen and only the Install OS mode but then it died again. I’m thinking maybe the rom was wiped somehow during shutdown causing a problem with the battery not charging. while connected. while at the same time the screen consistently flashes on and off when connected to the charger and the battery is dead. You can also feel the current vibrating while holding it when it’s plugged up. But since the digitizer is fine and it loads the OS install screen and shows the battery charger connected then the motherboard should be fine right? So if I can fix the battery situation and reinstall the rim it could fix it. I have all the soldering equipment and the know how to use it. So please tell me what I need to do. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Check the ribbon that goes between the charge port board and the board connectors for corrosion and dead solder joints under magnification if you can. It’s also possible the charge board could be damaged with the liquid too.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nick Wooten 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 782
