跳转到主内容
加入维修社区 - 创建账户
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
Mac won't start up, 3 short beeps at first, now nothing, how to fix?
The battery is definitely fully charged, no liquids, was working fine last night but it does usually run hot.
I replace the hard drive myself in April. I was going to replace the RAM just in case, but then the RAM was stolen/confiscated by TSA.
Any ideas what needs replacing/ repairing now? And extra helpful if there's a way to go about this in Playa del Carmen, Mexico. I'll have some time in the US soon, but I need my laptop to work in the meantime.
Running Catalina.
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@annelisse - I would still check the battery. You do have an onboard battery checker on the left side (well hidden) looking at the side straight on you should see a slightly raised round surface that’s the checker button and to its left are 10 tiny LED’s which should light up. How many and do they stay lit or blink?
完成的
@Dan The battery is fully charged. All lit up. I also replaced the battery myself last April.
完成的
添加一条评论
1个答案
最有帮助的答案
@annelisse - Review this Apple TN If your Mac beeps during startup
Likely a bad SO-DIMM or two, or it can be the clips aren’t holding the SO-DIMM.
这个答案有帮助吗?
得分 1
2条评论:
It's starting up now and works fine! Do you think that means it has to have been the clips and not the RAM itself? If so I'll buy replacement clips to have just in case it happens again just not sure if to reorder the RAM too.
完成的
@annelisse - The clips are not replaceable as they are part of the SO-DIMM socket part which in it’s self not replaceable either.
完成的
添加一条评论
添加你的答案
Annelisse Fifi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 112
