跳转到主内容
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
475 个问题 查看全部
Digitizer stops working at random intervals
Hello,
I have an iPhone 11, which is having issues with its digitizer. Every few days, it just stops working, and the screens becomes unresponsive. Now comes the fun part, if you force restart the phone, everything works as normal again. I already tried updating the software (and a DFU restore).
Ideas what this can be?
Thanks for the help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Unexpectedly it could be a battery related issue. I've heard reports of 'ghost touching' with poor health or poor quality battires.
Also clean and inspect the display itself many deep scratches or caked in grime can confuse the digitizer.
I had a similar issue on some iphone 12's unplugging the battery and letting it sit about 30 seconds seems to work, ios update stopped the bug my family and several coustmers with 12's had regularly.
Also reseat the display fpc, if it is slightly misset thermal expansion could cause an internment disconnect during use
Hope on of these steps fixes your issue.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem with an iPhone 11. After a while I found out that pressure on the screen (for example when the iPhone is in your pocket) is the cause. a foam layer between lcd and motherboard solved the problem for me.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ruby 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 76
