Flat ribbon cable is broken
Is there a possibility to get the ribbon cable between lower circuit board and top circuit board as a spare part?
I found this. Search for "30-Pin FFC/FPC Flexible Flat Ribbon Cable Pitch 0.5-1mm 6/10/15/20/25/30/40cm" on eBay.
I ordered the 0.5mm pitch, 25cm long. I get 5 for $1.40. I haven't got it yet. Let me guess, you dropped yours and split the cable?
这个答案有帮助吗?
I noticed your original post was for the Revolve (Non-Plus) . Mine was for the Revolve Plus. You can probably find what you need on eBay.
Unfortunately, I have not found one yet. Apparently there are not as a spare part.
Hans, did you read the part number off the cable. This place on eBay will make custom ribbon cables. Just figure out how many pins it is and what length you need. It is probably 0.5 pitch.
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 49
总计 358
1条评论
Did you find one as I'm after one too
由 Stu Taylor 完成的
