跳转到主内容
苹果2019年度的旗舰手机发布于9月20日,该设备配备5.8英寸OLED显示屏、三颗后置摄像头,电池续航能力大幅度的提升。为iPhone XS的后续机型。
150 个问题 查看全部
iPhone 11 restarting when audio is played
Hello, yesterday night I droped my phone in the shower and it got a little bit wet, though everything worked normally.
This morning when I woke up I found out that the phone keeps restarting when audio is played. So the phone will work normally until I try to play a spotify song or a youtube video etc.
I don't trust the phone not bricking itself if I try to restore it, do you have any advice on how to handle this problem.
Kind regards
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
6条评论:
Checking diagnostics I found that there are several files dated today that show AOP PANIC - No pulse on 0x11200e0 - main(5). Though I am not sure of what does it mean.
完成的
Bluetooth audio works, phone calls work with top speaker, but bottom speaker does not work on phone calls, though I did not experience a reboot
完成的
@willmontaraces can you post the actual panic? Even the first screen's worth of text is usually helpful.
完成的
@flannelist I tried to open up the phone and seems like I applied too little heat and broke the screen, now I have a iphone that restarts itself and with a broken screen. I think it is too expensive now to repair and it is worth it to buy another one. Thanks for your help
完成的
Sounded like you needed a new charging port assembly. The speaker and microphone are located on the same ribbon. Before you broke the screen of course.
完成的
显示更多的1条评论
添加一条评论
1个答案
hello Pablo,
no, all of the above advice seems wrong to me.
damage of this type always carries with it specific behaviors, which you do not write about, and it is really difficult to overlook it. Therefore, I believe that there is a broken connection of the motherboard and/or a short circuit in the boost circuits for the audio chips (the iPhone has three to four chips related to audio processing, each of them can cause similar symptoms). If you're not into microelectronics, don't do it yourself. Find a good repair service and order the diagnostics. On the other hand, this hypothesis will be confirmed (because you don't provide anything to prove this fault) only by the start.log or em.log (which in the latter case does not have to be so certain).
If I'm right, in a normal working good repair shop it shouldn't cost much. The time needed to perform the diagnostics of this device is about 10 minutes, the repair time will be 30-40 minutes. Total, about one hour.
Call somwere, find out, decide... you will surely find such a place.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pablo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 28
总计 393
