跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。可選GSM/CDMA,eSIM/nano-SIM,64GB/256GB/512GB,銀色/金色/太空灰色。讀法是“iPhone Ten S"。
Replace proximity sensor flex
Hi, broke the front speaker flex so replaced with aftermarket. I knew I’d loose Face ID, I can live with entering PIN all the time.
But the proximity sensor doesn’t seem to work. I’ve tried two different flex’s and both won’t dull the screen during call.
Is this normal when replacing the front speaker flex?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Make sure the proximity sensor can see. By that I mean make sure it’s seated in the holder correctly and lined up with the hole in the screen.
这个答案有帮助吗?
得分 1
添加一条评论
hello Chrisinuk,
No, the new replaced ribbon should support both sensors. In this case, check the connection, you may not have properly connected the connector to the port, which sometimes happens. Remove the battery, remove the TrueDepth ribbon and re-insert it, making sure it clicks into place properly. Connect the battery and start the phone. It should work.
I will draw your attention to the fact of the proximity sensor itself. If your original ribbon is damaged, there is nothing stopping you from moving your original FLOOD sensor to a new ribbon. It's just soldering :) and Face.ID will work again well. If you can't do it yourself, find a good microelectronics workshop and order soldering, it shouldn't cost much. I will add that it should take no more than 10-15 minutes. Cost - if someone can do it, the price will be lower. There is some dependence among mechanics learning from YouTube :) the more expensive - the more likely that someone does not know what's going on.
fingers crossing,
这个答案有帮助吗?
得分 0
1条评论:
Thanks guys, it must be installed incorrectly. I’ll check
完成的
添加一条评论
添加你的答案
Chrisinuk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 421
