跳转到主内容
This Chromebook is one of the many popular laptops given to students by schools. It charges via USB C and has 2 USB ports.
I tried to turn it on but it doesn’t turn on
So I got this Del Chromebook 3100 like 2 yrs ago from my old school and I just found it, I tried to turn it on but it doesn’t turn on I charged it all night but all it was doing was blinking orange is there a way I can fix this???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
You could probably disconnect the battery and plug the charger into the Chromebook and if that doesn't work, you need a screen replacement. it could be a possible issue with the screen if it's broken because if you damage the screen enough, it will turn black with no signs of life or it could possibly be disconnected. If the screen works without the battery, You need to replace the battery if it won't hold a charge and try the hard reset method by pressing the refresh button and the power button and if that works, you're good to go!
完成的
添加一条评论
4个答案
最有帮助的答案
Hello Jairo,
If the device is flashing orange and is plugged in, this may be a battery issue.
You can also try a force restart to test it further. You can do this by pressing and immediately releasing the "refresh" key and the power key simultaneously. If the device still doesn't power on, you may need to replace the battery.
Best of luck.
这个答案有帮助吗?
得分 2
2条评论:
According to Dell, a blinking orange battery/status light indicates a battery error, so yeah, replacing the battery would be the next logical step.
完成的
Hey I have a problem my Chromebook
完成的
添加一条评论
HP chromebooks too!
When my chromebook is plugged in with orange light(mine was solid). and won't turn on, I have found the "force start" by pressing refresh and power button for a short simultaneous push works for the hp chromebook as well! Thank you!
这个答案有帮助吗?
得分 0
添加一条评论
You can also disconnect the battery to reset it and plug it back in, you have to plug it back in to rest the battery. alot of people think the power button is to turn it on "NOT so" you are just shutting it off again.
When you open your chromebook that is how it turrns on.
这个答案有帮助吗?
得分 0
添加一条评论
just charge it overnight
这个答案有帮助吗?
得分 0
1条评论:
This doesn't seem helpful since the original poster specifically said they had charged it overnight.
完成的
添加一条评论
添加你的答案
Jairo Santos 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 91
总计 5,089
