跳转到主内容
The Flipper Zero is a versatile multi-tool device designed for hacking, debugging, and experimenting with various electronic gadgets and systems, such as sensors, receivers, and other electronic components.
GPIO 17 for iButton Came off
Help, how do I repair GPIO 17 pins at the back which is used for the iButton feature? Tried opening the device and the clips were bit to tight when prying open and when I lifted the cover off it took two pins of the GPIO 17 off. Any suggestions on how to fix? Doesn't look like a solder tho..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Have you resolved your issue? im having the same problem help please
完成的
添加一条评论
1个答案
最有帮助的答案
Unfortunately, the Flipper team does not currently sell replacement parts. However, you can contact them to be added to their waitlist.
Another option is to purchase a broken Flipper Zero that still has a functioning GPIO module and use it in your device.
You can also bypass the iButton pin by just connect a wire from GPIO pin 17.
这个答案有帮助吗?
得分 1
1条评论:
NOTE: The Flipper team has begun selling parts to people who’s on the whitelist, don’t know how long it will take for them to be available for everyone but for now they only sell 2 parts (Top Case and Screen). You need a code to order the parts, you can order them on https://shop.flipperzero.one/collections...
完成的
添加一条评论
添加你的答案
Raymond 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 27
过去 30 天: 87
总计 2,007
