跳转到主内容
This guide page will help you diagnose problems with the Toshiba Satellite C55-B5200.
9 个问题 查看全部
HDD not detected in SATA Battery Life Mode
This laptop has a "Performance" and "Battery Life" setting for SATA in the BIOS.
I have installed a clean version of Windows 10 after upgrading to a 1TB SSD (Team
Group AX2)
The laptop will boot fine if the "Battery Life" setting is selected. SATA speed is 150 MBS.
However, if I change the BIOS setting to Performance", the HDD is not detected by the BIOS. However, I can Read/Write the disk while in Performance mode using the disk tools on the USB drive.
Simply changing the BIOS setting to "Battery Life" allows it to boot properly.
Has anyone seen this??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
The problem turned out to be the new SSD drive (Teamgroup AX2 1TB).
Bought a Crucial 1TB SSD and the laptop now detects the drive when the BIOS is set to "Performance" mode.
It must have been some problem with the handshake during boot.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dan Pinvidic 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 9
过去 30 天: 10
总计 173
