跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
How to merge second partition back to main SSD
I installed a 500gb SSD in my Macbook and created an extra partition there with 100gb.
Now I want to merge the partition back into the SSD but unfortunately I always get an error when I press restore.
What did i wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Not understanding why you are restoring.
First you do want to make a good backup of both partitions independent of each other TimeMachine will only do the primary (boot volume) so your second volume won’t be backed-up. As you have a small volume just copy the data off to an external drive. Now what is important here is the partitions type may not be compatible with each other and the data held might not be accessible within the Mac apps (I.E. Ms Windows or Linux)
You also need to use disk utility to delete the second partition then you can extend the primary, and lastly copy back your stuff.
这个答案有帮助吗?
得分 0
2条评论:
Drive genius is a good program.
https://www.prosofteng.com/drive-genius-...
完成的
@miket19 - It is! I use it, but… It’s not needed here.
完成的
添加一条评论
添加你的答案
Marv 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 99
