跳转到主内容
Repair and disassembly information for the first generation of Apple's high-end wireless earbuds. Released in October 2019. Identified by model numbers A2084 (left earbud), A2083 (right earbud), and A2190 (charging case).
71 个问题 查看全部
AirPods wont connect unless plugged in.
My AirPods Pro earbuds do not connect to my devices unless they are plugged in. They also cannot go into pairing mode, I hold the button on the back of the case for any time period and the light will not turn white. I open the lid and the light is green right away but after about 4-5 seconds of holding the button, the light shuts off then turns green again in a few seconds and doesn't stop doing that. This is a big issue because I recently got a new phone and my AirPods won't connect it.
Please Help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Close the lid, wait 15 seconds, then open the lid. Press and hold the setup button on the charging case for up to 10 seconds. The status light should flash white, which means that your AirPods are ready to connect. Hold the charging case, with your AirPods inside and the lid open, next to your Mac
Regards,
Will
这个答案有帮助吗?
得分 0
1条评论:
I already tried that, the indicator light will not flash white.
完成的
添加一条评论
添加你的答案
Tysen Grinde 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 17
总计 302
