跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
No EFI Boot for Dual Boot Linux after replacing SSD
I changed my SSD on my MacBook Pro and installed Montery.
Today I tried to install Ubuntu dualboot but there is no EFI.
What did I wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I’ve heard issues with newer macOS this can happen as the virgin drive which is setup with High Sierra or newer which sets up a very different drive structure that the older Sierra macOS. Basically, this is related to the change from HPS+ to APFS file system.
So… if you had upgraded the remanence of he old would still be present.
You’ll need to reformat the drive removing all partitions, install Sierra in one partition then install Ubuntu in a second partition. You should be able to jump between using the onboard Startup Manager using the boot-up smart key service pressing the Option key.
Then you should be able to upgrade to Monterey and then use the Ubuntu dual boot option.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marv 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 87
