跳转到主内容
加入维修社区 - 创建账户
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
MacBook thinks it's dead after sleep despite full charge
After installing a replacement battery from iFixit earlier this year, my Macbook has not been waking up from sleep unless plugged in (i.e. after I have the lid closed for some time). I press the power button and the dead battery/charge icon appears.
It will only turn on when I plug in the power adapter, even then the battery will show a sufficient charge once it's on. This morning it happened after it wasn't plug it in over night, the battery was at 90% when it turned back on after plugging it in.
I already tried doing the calibration charge/decharge cycle, and also resetting the SMC and PRAM/NVRAM multiple times, nothing seems to fix it.
Apologies if this has already been posted about/resolved. I've already tired a google search, but no one seems to have the problem with the circumstances I have.
Thanks for your help!
Mid-2015 Macbook Pro with Retina Display
SSD upgrade
Battery replaced
Update (01/17/2023)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You may have a bad battery, install this gem of an App CoconutBattery so you can see more clearly the batteries status. Post a snapshot of the Apps main window here so we can see it too.
这个答案有帮助吗?
得分 1
6条评论:
Apologies for the late reply! Thanks for the suggestion. Just added in the screenshot to my original post. Seems like all is good? I just installed the battery about a year or so ago.
完成的
@garet - let’s get another snapshot while the system is under charge as the battery is quite low and we want to see the temp while under charge but not after it’s fully charged.
完成的
@danj thanks for the clarification. New photos added show the macbook as it is charging around 70%. I'll provide any more information as needed.
完成的
@garet - When did you replace the battery?
完成的
I replaced it almost exactly a year ago last January, 2022
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Garet Greitzer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 274
