跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
563 个问题 查看全部
Bad SMC even after logic board replacement
Basically what the title says. Macbook was running super slow and fans full blast. Apple diagnostics came back with bad SMC and power management system (PFM006 and PPN001). So I replaced the logic board and I'm getting the same issues. What could cause this? No water nor apparent physical damage to the Macbook.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Turned out to be the top case somehow. The battery looked fine in CoconutBattery but the machine ran glacially slow--took like half a day to finally log in and get CoconutBattery to run (not even exaggerating, sadly). Replaced the top case, and with the original logic board, battery, and screen, it runs like a top. Who knew?
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
SMC errors are common even if the board itself is not at fault. It's much more likely to be that the SMC is not hearing from one of the many sensors throughout the computer, or one of the sensors is getting bad readings. Agree that it's possible your battery is at fault based on the power management error.
Some parts of the power management system in this model are on the battery board, which is separate from the logic board.
If you've already gone through all the trouble of replacing the logic board, I would see what happens if you try to run diagnostics with the battery intentionally disconnected. Or at least the battery data cable. See if you get different errors. If you just get a battery not detected error in diagnostics, seems like the battery is likely to blame. You may still get SMC errors (because there will still be sensors it's not getting expected values from), but see if it resolves the Power management one.
EDIT: Battery data cable in question is circled. The big fat screw with the arrow pointing at it is for the actual power from the battery coming into the board. All the little cable does is report things like presence, charge levels, temp, etc….
这个答案有帮助吗?
得分 2
2条评论:
Can this model be started up with the battery disconnected? Seems like it won't turn on when the battery is fully discharged and needs at least 1% power to boot, otherwise it shows the charging icon. I'll see if I can do it with the battery data cable disconnected (once I figure out which one that is lol). Cheers
完成的
@maccentric Absolutely. Unless they’ve bad some changes to firmware I don’t know about, but I haven’t ever had a problem doing so on this model. Battery data cable I’ll add a picture for to my original answer, but it’s the little flimsy one that goes over the big fat screw along the edge of the logic board closest to the battery.
完成的
添加一条评论
Diagnostics is a bit tricky! You’ll often get a SMC error, but no because of its failure only the fact the signal it’s expecting failed from upstream. Here it’s likely your battery voltage sensor.
Download this gem of an app CoconutBattery post a snapshot of the main window with battery tab exposed so we can check things out.
这个答案有帮助吗?
得分 0
4条评论:
I think this is likely the answer. I've tried to run coconut battery but the thing is so frustratingly slow right now that I've given up and just ordered the battery on the assumption the electronics in it are bad. I'll report back with an update when I get it installed, thanks!
完成的
Well, replaced the battery and still getting the same error codes and behaviors. Any other ideas?
完成的
@maccentric - Can you post a snapshot of CoconutBattery with the new battery
完成的
@maccentric - This is an odd one for sure! This points to to the palm sensor failure. The Touchpad is where it is mounted in the 2015 and older systems. I haven’t dug into the Touchpad in this series yet you might want to give that a try.
完成的
添加一条评论
添加你的答案
maccentric 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 412
