跳转到主内容
加入维修社区 - 创建账户
The Xiaomi Redmi Note 8 is a mid-range smartphone by Xiaomi released October 2019. It has a 6.3" IPS LCD display, a 48 MP main camera, a rear-mounted fingerprint sensor, a 4000 mAh battery, and runs on a Snapdragon 665.
Why does my phone doesn't show any signal from my sim card?
I've added a sim card to my phone(Redmi note 8) but it doesn't show any signal it only shows that the sim card is inserted. I've tried to call someone and it shows me to "Turn off airplane mode to make an call" although my airplane mode isn't on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
4条评论
Is this phone unlocked to use on any cellular network? Sim card faulty? Can you try another sim card?
完成的
@notbroken The phone is unlocked but i still cant activate the cellular network.Even if i use another sim card it shows that a SIM card is in the phone but it has no signal.
完成的
عندي سؤال لمادا يطفيء الجهاز وحده بدون ادني مشكل
完成的
عندي سؤال لمادا يطفيء الجهاز وحده بدون ادني مشكل هل يوجد تفسير
完成的
添加一条评论
1个答案
已选择的解决方案
There are several possible reasons why your phone might not be showing a signal even though you've inserted a SIM card. Some possible reasons include:
  1. The SIM card is not properly inserted into the phone. Make sure that the SIM card is properly seated in the SIM card tray and that the tray is securely closed.
  2. The SIM card is not activated. In some cases, you may need to activate your SIM card before it can be used. Contact your mobile service provider to ask about activating your SIM card.
  3. Your phone is not compatible with the SIM card. Not all SIM cards are compatible with all phones. If you've recently switched to a new phone or a new mobile service provider, make sure that the SIM card you're using is compatible with your phone.
  4. There is an issue with your phone's software. In some cases, a software glitch can cause your phone to not recognize the SIM card. Try restarting your phone and see if that fixes the issue.
这个答案有帮助吗?
得分 3
2条评论:
none of these fixed my issue...I even flashed my phone
完成的
Saya memiliki masalah ponsel yang sama bahkan HP saya tidak dapat menangkap sinyal Wifi semua sinyal benar-benar tidak berfungsi di HP saya dan menurut beberapa informasi ada bagian ic di area mesin yang harus diperbaiki dan saya mau mengkonfirmasi apakah benar ada ic di area mesin khusunya bagian sinyal yang diperbaiki, apakah ini valid?
完成的
添加一条评论
添加你的答案
Lucarcio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 25
总计 7,564
