跳转到主内容
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
Why does my iPad digitizer not wok?
I bought an iPad 5 wifi digitizer from IFixit.
When I first applied it the corner did not work but after that the entire left portion of the screen was not working, I may not go for a refund because the process isn't worth the effort but I will definitely leave a bad rating!
why did this happen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Philip, it seems unfair of you to "leave a bad rating" because you're not willing to take the few steps needed to talk to the iFixit Store staff about a replacement. Your digitizer has a lifetime warranty, and I've found the staff to be extremely responsive and helpful.
They specifically select their parts for high quality and longevity, but like anything it's always possible to get a bad apple in the bunch. The good news is they stand behind their products and are happy to help.
So please, take @strongbow's advice and check the connectors, and if you're still having problems contact iFixit at support@ifixit.com and they'll take care of you.
这个答案有帮助吗?
得分 5
3条评论:
@dadibrokeit , I had another digitizer on hand which fully worked on the iP, thus I will claim it on the warranty! Ill give you an update when I've refunded it!
完成的
I have gotten the refund from Ifixit, I am very please with the polite service of the support team!
完成的
@ch_w Well, I'm sorry to hear you had an issue with the replacement part from iFixit, but glad to hear you got it resolved to your satisfaction. I will personally continue to buy from them thanks in large part to their excellent customer service department.
完成的
添加一条评论
最有帮助的答案
Disconnect the connectors and refit them again making sure they’re seated properly. Sometimes they look and feel like they’re connected but they’ll have a partial connection. Disconnecting the battery first of course. If that doesn’t help then it could be the screen or a failing part on the board itself.
这个答案有帮助吗?
得分 5
2条评论:
Thanks, Ill try that!
完成的
完成的
添加一条评论
添加你的答案
Philip 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 213
