跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
276 个问题 查看全部
Keyboard and Trackpad not working, very slow and fans on full blast
Logic Board front:
Logic Board rear:
I have a MacBook Pro 13 Touchbar A1706 EMC3163, mid 2017 model with a number of (probably liquid spill related) issues:
It started booting very slowly and as soon as the OS boots up, the fans are running at full speed and the MacBook is very slow, almost unresponsive. (Safe mode to protect the system???) One by one the keyboard and later the trackpad died.
PRAM and SMC reset are no longer possible (because of the broken keyboard). I did, however, drain the battery completely, which should work as an SMC reset (and didn't help).
When booting in diagnostic mode, it shows a problem with the System Management Controller (code: PFM006) and a problem with the Power Management System (code: PPN001).
I would like to fix it by buying a donor Macbook, and I hope to fix my Macbook by replacing the logic board and probably the keyboard and trackpad. Since I'm not familiar with Apple products, I'd like to get feedback on whether this is doable (if there are any particular challenges) and whether my assessment that the logic board is defective is correct.
I greatly appreciate your comments and help,
Thanks,
Felix
Additional information:
The battery works fine and powers the computer for several hours,
the currently installed operating system is Monterey
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
11条评论
Hi
At the moment it’s sounding like it could be spill related as you have already said
Let’s try and confirm this,if you could open the MacBook apart using this guide
2016年末带Touch Bar的13英寸MacBook Pro 底壳更换
And upload some photos on the inside using this guide
在已经存在的问题里加入图片
that will help us get a better idea of what’s going on :-)
完成的
Thanks for your reply.
I'll try to open the MacBook tonight and upload pictures :)
完成的
@fritzpeppone - even before you open the system how about running the onboard diagnostics to see if an error pops. Restart your system and press the D key to enter.
Reference: Mac startup key combinations
完成的
@danj That's exactly what I did and described above:
"When booting in diagnostic mode, it shows a problem with the System Management Controller (code: PFM006) and a problem with the Power Management System (code: PPN001)."
完成的
@hellomacos I just opened the MacBook and uploaded some pictures. At first glance I don't notice anything out of the ordinary. No corrosion, no obviously defective chips/components. One of the batteries looks slightly bloated thought...
完成的
显示更多的6条评论
添加一条评论
2个答案
已选择的解决方案
@fritzpeppone - The SMC error is just a reflection of the true error which is within the power management logic within your logic board.
This is likely a damaged component or corrosion damage on the logic board (of course the side you can’t see from the bottom)
I think it’s wise to find someone with Mac logic board repair experience to help you here.
这个答案有帮助吗?
得分 3
1条评论:
danj said right things
完成的
添加一条评论
I've retired loads with this problem and 90% its the trackpad , which is a cheap and easy fix ( just be careful with the washers )
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Felix Buchele 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 16
总计 303
