跳转到主内容
加入维修社区 - 创建账户
M1 Mac mini 是Apple的首部使用自研單晶片系統(SoC)的機型之一,整合了中央處理器(CPU)、圖形處理器(GPU)、記憶體(RAM)等等主要元件,以提升能耗比。此代Mac mini 的M1芯片CPU擁有8個核心,其中有4顆是效能核心(P-Core),而另外4顆為效率核心(E-Core),並帶有8核心的GPU。
Mac mini Late 2020 won't boot but has yellow light indicator
Why Mac mini Late 2020 won't boot but has yellow light indicator, no video
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
This is one of Apples Least repairable systems as just about everything is solder to the logic board.
I would find my way to an Apple Store as this sounds like a logic board issue.
这个答案有帮助吗?
得分 2
添加一条评论
A solid amber or yellow light (depending on what you want to call that color) means the device is in firmware recovery mode. Likely the firmware is corrupted, or damaged so instructions the computer needs to boot up properly are missing, or incorrect.
If you have access to another Mac you can try using Configurator 2 to revive or restore the device. Revive should not affect the onboard storage, and is generally safe to do without fear of data loss. Restoring the device will wipe the internal storage, so you will want to make sure you have a backup or have come to terms with data loss before you perform a restore.
If it’s stuck in recovery mode and Configurator 2 does not correct the issue, or you don’t have access to a second Mac, this might be a job for a repair shop depending on what the actual issue is, but it is likely to be a logic board level issue if revive/restore does not work. See Apple if you’re still under warranty or have AppleCare on the device.
If you do perform a restore and it fails, make note of the error you receive since it can help diagnose the issue.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
smartmacs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 1,514
