跳转到主内容
Steam Deck 是 Valve 公司于 2022 年 2 月 25 日发布的游戏掌机。本页面包括 Steam Deck 搭载 LCD 屏幕机型的维修指南、拆解信息,以及疑难解答。机型代号1010。
When will there be trackpads available?
My left trackpad is stuck and makes a cracking sound when gently pressed. Was hoping to find replacement.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
最有帮助的答案
Hi
Unfortunately this part doesn’t appear to be available yet probably because of how new the device is
However I do have a solution for the issue you are having
1)you could contact valve and see if you can have it repaired under warranty (if it’s in warranty of course)
Or
2)you could follow the guides likened below
更换 Steam Deck 左触控板
更换 Steam Deck 右触控板
And try carefully cleaning any debris away using isopropyl alcohol and a soft brush ,doing this will hopefully clear away what’s causing your issue
Hopefully this helps
Any questions please ask
Steam Deck 左触控板图片
指南
更换 Steam Deck 左触控板
难度:
中等
1 - 2 hours
Steam Deck 右触控板图片
指南
更换 Steam Deck 右触控板
难度:
中等
1 - 2 hours
这个答案有帮助吗?
得分 1
1条评论:
Greetings. I'm in need for an OLED Right touchpad.
I did a shell replacement, including the surface plastics. I'm not 100% sure, but I think I scraped a tiny resistor from the back of the pad board as I see 2 shiny spots next to 2 other components. In any case, aside of all ribbons and cables being correctly set, the touchpad is dead and I need a new one.
Any info on availability?
Thank you, and please be safe!
JGG
完成的
添加一条评论
I had this problem from a single drop of soda that managed to fall in the crack between the touchpad and case.
I took out the touchpad and but was unsuccessful in getting the touchpad itself apart. There's 4 tiny retention clips holding it together that were giving me trouble.
I instead submerged it partially in isopropyl alcohol, let it fill, drained it, repeat. After a few times I dried it off, used compressed air to blow out any remaining internal moisture, then reinstalled.
Worked like new.
这个答案有帮助吗?
得分 1
1条评论:
My right tackpad is damage and I absolutely need a replacement for it. When will they be available? They were announced back in September 2022 and it is now may 2023
完成的
添加一条评论
添加你的答案
Connor Minton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 61
总计 1,869
