screen says no signal
TV says no signal on screen when connected to a working cable box
probably, a loose cable OR, I had a problem similar to this, my satellite cable goes over the roof, and the weather had weathered it and it wouldn't work. get a new cable or my grandparents had a similar cable to this as well, they just had a bad signal though, they had to get their satellite replaced as some water got into it. hope this helps :)
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 15
总计 356
Hi,
What is the model number of the TV?
Have you checked that the TV input is selected to the correct input that the cable box is connected to?
Have you tried a different known working compatible cable between the box and the TV to see if that worked?
What have you tried?
由 jayeff 完成的
