跳转到主内容
Huawei Fit is a lightweight fitness tracker and smartwatch, released in November 2016.
2 个问题 查看全部
How do I replace the battery on the huawei fit smart (MES-B19) watch.
I have a huawei fit smart (MES-B19) watch. The watch doesn't hold a charge. But it's on when it's in it's charging cradle. As soon as I either disconnect the cable or lift the watch off of it's cradle the watch goes black. Everything works while it's in it's cradle. I have watch repair tools, but can the watch battery be replaced with another battery from another huawei fit smart MES-B19 watch? This watch is in perfect cosmetic shape taking the fully functional battery from one that's not in good cosmetic shape.
Could someone give me step by step guides on how to do this to make sure I don't mess something up. Also do I have to replace the glue and seal on the watch when putting it back together.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@rhall260 This video isn’t specifically for that exact model, but should take you through the process of opening and fixing the watch. Just use care and caution, and remember to carefully keep track of which screws and parts go where. Putting the wrong screw in the wrong place, is a bad thing.
Yes, you can use a battery from another watch, as long as it’s the same exact model.
这个答案有帮助吗?
得分 1
添加一条评论
https://consumer.huawei.com/uk/support/h...
Here is a link take care!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
robert hall 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 40
总计 608
