跳转到主内容
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
308 个问题 查看全部
Why is my Xbox not showing up on TV but the power button is green
A while ago , I was trying to update my RGH Xbox 360 to the latest dashboard. When I finally put the update file the xbox turned off, when I turned it back on the power button was green but nothing was shown on the screen , I tried connecting my controller but It didn't work. I also tried booting the xbox from XELL but it didn't boot into XELL. I still have the flash dump file and the update file . Is there a way to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
If it’s homebrew software it’s mostly likely Microsoft bricked your system because of the update and or it could be the av port probably you just need to clean it
这个答案有帮助吗?
得分 0
3条评论:
I didnt go online, I downloaded the dashboard update manually, I tried changing to HDMI but it's still the same result
完成的
Still the system could detect it
完成的
It probably the moniter or the hdmi por this dirty and needs cleaning or replacement since you said it works on your friends moniter
完成的
添加一条评论
If you can, try plugging in your Xbox through the HDMI cable, and if that's already your configuration, try plugging it in through the AV port. Hope this helps!
Cheers
Diode
这个答案有帮助吗?
得分 0
4条评论:
I tried with HDMI but it still gives the same result, my configuration was using AV port.
Any other way to fix it?
完成的
@Karim Hourani (Proboss) Did you try on a different monitor or with different cables?
完成的
Yes I did, Sorry for late response
完成的
@Karim Hourani (Proboss) That's all right. If you tried that and it didn't work, sorry, but I can't help. Sorry again.
完成的
添加一条评论
Have you checked the HDMI port, I have seen pins bent before making the port unusable. You can also clean it out with air and little alcohol.
这个答案有帮助吗?
得分 0
2条评论:
I just checked the port , its completely fine. I checked it a while ago too it was fine , I will try cleaning it perhaps that will work out.
完成的
Theres something I want to add, my xbox 360 actually stopped working as soon as the dashboard update finished,(I downloaded it manually)
完成的
添加一条评论
If you updated your Xbox to the newest dash board version that means that the nand you used is either corrupt or not properly dump and you just write on your Xbox that can bring problems if you want to fix it search on YouTube how to fix corrupt nand
这个答案有帮助吗?
得分 0
2条评论:
It might need a jr-programer
完成的
Ok, I'll try
完成的
添加一条评论
添加你的答案
Karim Hourani (Proboss) 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 28
总计 797
