跳转到主内容
An update to HTC's original Vive, now with improved displays, sensors, and ergonomics. Released April 5, 2018.
27 个问题 查看全部
Will your Vive Pro Headphone replacement part fit the Vive Pro2?
Hi, I have a Vive Pro 2 Headset and the left earphone is failing [sound stops playing on the left side]. Will your replacement part [Item # IF453-028-1 HTC Vive Pro Headphones] fit the Vive Pro 2 headset?
I have already removed the left earphone and verified that the contacts are clean. The sound is intermittent. I need a replacement part for the left earphone that has the volume control button.
Has anyone successfully used these replacement headphones on a Vive Pro 2 Headset?
Thank you,
Edward
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hey, Edward.
As long as you're capable of doing it yourself, I'd say it's fine to use a Vive Pro Headphone replacement on the Vive Pro-2. There is not too much differentiation between the two headphone parts, and certainly not enough difference to cause an issue. I hope you find this helpful.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Edward Leslie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 55
