跳转到主内容
加入维修社区 - 创建账户
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
bluetooth devices not working
I've checked for previous questions seems that nobody has had an issue like mine. my ps3 works fantastic. model#CECHL01 its an 08 model, and still like new , the only issue I'm having is nothing bluetooth works, mic, controllers I've even bought new controllers nothing...I reset controllers and system same result, help what is problem so that i can use the wireless devises on my ps3
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
thank you cody yes this will help i was unsure if wife and bluetooth were the same board but thanks for the e-bay find i thought they would be more expensive
完成的
glad i could help out
完成的
添加一条评论
1个答案
已选择的解决方案
it sounds to me like maybe your bluetooth module is bad...there are a few on ebay here....they are pretty cheap just make sure you get one that will fit your model ps3 (i believe that any will fit yours except for the first few models that had 4 usb ports). For instillation you can follow this guide to step #12 but only remove the screws holding the bluetooth module in place and then just swap out and follow the guide backwards for re-assembly.
Hope this helped,
Cody
这个答案有帮助吗?
得分 3
1条评论:
i appologize but this is actually the correct guide...sorry for the confustion.
完成的
添加一条评论
添加你的答案
Louis 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 89
总计 38,453
