跳转到主内容
Repair guides, disassembly, and troubleshooting information for the second generation Sony PlayStation 5 DualSense controller. Identified by model number CFI-ZCT1W and motherboard model BDM-020.
Pressing the X button presses also the PS button! Please read below
When I press the X button, the PS button acts like it's pressed plus the controller doesn't turn off.
The controller works perfectly besides from that!
Tried resetting the controller didn't work. Tried cleaning the surface and get some isopropyl alcohol under the X-button, didn't do it correctly but still the controller didn't work.
Called some local repair shops, some responded that I just throw it in the garbage.
What might be the problem? What might be the cause? and how to fixit?
The controller is new (2 months old) I'm out of the US before suggesting warranty replacement.
Update (4/8/2023): It is fixed!
Thank you all for help! Just checked as you guys suggested the conductive film (the green/blue board underneath the buttons), Cleaned it with cotton soaked with isopropyl alcohol, now it works again!
This is a YT tutorial
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
I’d say it be a problem with the membranes or the contacts on the board it’s self in sorry that the stores are telling you to throw it away never do that the reason I think they said that is because the controller is kinda infamous for being hard to repair
这个答案有帮助吗?
得分 2
7条评论:
So do I just disassemble it and clean underneath?
完成的
I would say to yes sorry for the late answer but be careful k
完成的
Dont worry, follow this guide. 100% it will be okay.
The problem is in the circuit board. The little green/blue board flex which has the circuit lines.
Simply remove the inner black case and then turn it upside down there you will see the board flex. Then replace it
完成的
@mondelegend Thanks a TON!!! I didn't replace it, just cleaned the board flex with isopropyl alcohol (put a drop on a cotton and passed it through the circuit lines and these black circular thingies that lie under each button), it worked like charm!!
完成的
It's a late thanks to you for pointing it out, just disassembled the controller and cleaned the board with isopropyl alcohol, no problems at all!
完成的
显示更多的2条评论
添加一条评论
Is there any other way besides taking it apart with screwdrivers?
这个答案有帮助吗?
得分 2
1条评论:
It’s because of the controller fault. Change the controller it should work.
For me also it was the same problem. After changing the controller it got fixed.
完成的
添加一条评论
添加你的答案
Moe hamm 将永远感激不已
浏览统计数据:
过去 24 小时: 24
过去 7 天: 151
过去 30 天: 752
总计 19,455
