跳转到主内容
加入维修社区 - 创建账户
The iRobot Roomba 692 is an automated robotic vacuum cleaner that is part of the iRobot Inc. 600 series Roombas.
Why won't my roomba 692 charge?
I've had the roomba 692 for less than 6 months, but it won't charge anymore on the charging doc. Is it the charging dock that's the problem, or is it the roomba's charging pad or motherboard. I am going to send it in to get it repaired, but would like to see if i could figure it out myself.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You can check if there is a problem with the power outlet where you have plugged your charging station. Try using a different power outlet. Also, inspect the power cable and its connection to the power inlet port on the charging base. Secure it in place firmly and then check if the charging base turns on. Another issue can be due to insufficient voltage. You can check if you have sufficient voltage at the mains. Sometimes, just turning the breaker switch on and off also does the job. For more troubleshooting tips like these, you can check out detailed Roomba troubleshooting steps here.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
tayola 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 934
