跳转到主内容
Repair guides and support for your Philips TV.
226 个问题 查看全部
Why is my TV showing black after software update.
My 5700 series 4k ultrahd led tv went black (Still almost lights a dark room though) Came home from out of state to my TV showing a message about download new software update. Clicked on it only for the TV to go black , pressed the romote off only for it to blink several times no response. The actual TV buttons are the same way No Response..Any idea what the problem I've only had the TV a year really can't afford a new one..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @irisplease.
Try disconnecting the power from the TV and then press and hold the TV's Power On button (not the remote) for 30 seconds and then release it. Reconnect the power and check what happens when you try turning it on.
If still no good, you said "...I've only had the TV a year...", if so check how long you have actually had it.
If it is <12 months contact the Philips customer service section in your location (check the user guide perhaps for contact details) and get it repaired under warranty.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
IrisP 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 248
