跳转到主内容
Released in 2012, the Asus N56VZ is a 15-inch laptop with a screen resolution of 1920x1080 pixels. It has an Intel Core i7 and an Nvidia graphics card inside.
12 个问题 查看全部
no sound but headphone fine
sometimes I get sound from speaker but most of time there are no sound from speaker while from headphone port works fine.... I checked drivers and I am definetely sure it is hardware issue so what should I do please help me...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
I do not see a repair guide for the N56VZ on iFixit.
You could buy them and then write an iFixit guide for how to replace them!
这个答案有帮助吗?
得分 0
添加一条评论
Try running the audio troubleshooter. Open a command prompt window by typing CMD in the search box at the bottom of your display. Right-click Command Prompt from the list of options and select Run as an administrator.
In the command prompt window, copy and paste the following and follow the prompts:
%systemroot%\system32\msdt.exe -id AudioPlaybackDiagnostic
Select your speaker from the list of audio playback options to troubleshoot it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Allaberdi Nurberdiyev 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 71
