跳转到主内容
三星公司于2018年3月发布的旗舰手机,盖乐世 S9。
137 个问题 查看全部
Phone gets too hot easily Replacement Screens keeps getting damaged
I've changed my s9 screen thrice now, it still develops some sort of fault after some time and goes blank, the phone heats up more frequently than normal during usage.
I keep suspecting if there's something damaging screens in the phone, maybe the heating or the panel, I don't know.
I was hoping to get some answers.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Run the phone in safe mode if you can. If it still gets excessively hot, you more than likely have a short on the board somewhere. Excess heat is a typical sign of a short. A quick and easy way to find it would be to use a can of electronics dust off you find at office supply stores. You can turn it upside-down and spray the board until a frost forms before you turn it on. Just watch your hands because it's extremely cold and contains a bitterant. The component that's shorting out will thaw out faster. Just bear in mind that component may not be the actual cause of the short. Something else could be causing the short to form on that specific component. Make sure to wash your hands thoroughly after using the dust off. Like I said, it contains a bitterant and you'll taste it if you eat food with your hands and it's not very pleasant.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Geny Shantel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 49
