When my ceiling fan rotates the noise is like type writer
When my ceiling fan rotates the noise is like type writer hitting sound . What could be the problem?
Hi Sethuraman,
I just went through this at my son's house; all of his ceiling fans were noisy in different ways; on two of them the blades were loose and just had to be tightened; the other one wasn't mounted well to the ceiling and had to be resecured.
So yeah, grab a Phillips screwdriver and tighten all the screws that hold the fan blades onto the motor. I'd almost be willing to bet that will take care of your noise.
Good luck; let us know how it goes!
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 63
总计 110
Hi,
Does it also make the noise if you rotate the fan blades manually i.e. not by using the power?
Are any of the blades loose at all?
由 jayeff 完成的
