跳转到主内容
加入维修社区 - 创建账户
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
The iMac won't turn on
Checking indicator lights
I Plug the iMac in, LED 1 would light up; press power button then LED 2, 3 and 4 would turn on then all LEDs turn off
Would appreciate help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
This sounds like you have a bad capacitor on the logic board. This will take a bit of effort to nail down. You’ll need to find the schematics and board view drawings to trace out the voltages. Your other option is getting a replacement logic board.
这个答案有帮助吗?
得分 0
4条评论:
I don't see any capacitor on the logic board what does it look like?
完成的
@elchanan1 - Can’t see the tree in spite of the forest! I would say have of the small SMD components on the logic board are caps.
You really need the schematics and boardview drawings and the skills to work off of them with a DVM to ID the bad one as often there is little to go by.
完成的
In the end I replaced the capacitors in the electrical panel and now it works
完成的
完成的
添加一条评论
添加你的答案
Elchanan Blumenfeld 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 135
