跳转到主内容
First generation, based on the Ford C1 global platform.
35 个问题 查看全部
Power steering light on
I have Mazda 3 2004 diesel. Power steering light on. When the light turns on, I turn off the engine and start again, and the light goes, but after a while, it turns on automatically again, specially when I turn the wheel al the way to the end. Do I need to change the fluid or do I need to add more fluid? I also want to know what type of fluid should I put for my car mazda 3 2004 diesel. Or is it some other issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Check if the power steering fluid is the correct level and that there are no obvious leaks near the power steering fluid cylinder etc.
Here's some images form the 2004 Mazda 3 owner manual that may help.
(click on image)
这个答案有帮助吗?
得分 1
2条评论:
What type of fluid should I add. I don’t have the book for all that information. Which is do I have to buy. Car type Mazda 3 2004 1.6 diesel
完成的
@mzemar119 Your car is like my Volvo; it uses automatic transmission fluid for the power steering. The type is circled in red on the last picture @jayeff posted; go to an auto parts store and ask for a quart of Dexron-III (say "Dexron three" transmission fluid.
完成的
添加一条评论
添加你的答案
mzemar119 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 27
总计 411
