跳转到主内容
加入维修社区 - 创建账户
任天堂于2019年9月20日发布了在Switch系列中更加实惠、且更纯粹的掌上游戏机——Nintendo Switch Lite,它有着一体式的手柄设计以及更小的屏幕。
Not switching on after fall
My son's Switch Lite fell off his bed and now it won't switch on. There's no apparent physical damage and I can't see any obvious loose connections. It has plenty of battery.
Anyone got any suggestions for what it may be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
does it make any sounds when the buttons are pressed if it does it could be the screen, other than that there are various reasons that could cause it like cpu being damaged, but its nothing anyone can diagnose online
这个答案有帮助吗?
得分 3
9条评论:
Thanks for replying.
No, no sounds. Fully dead. That is why I thought a loose connection.
Sounds like it could be just about anything, then. I was hoping that there may be a couple of likely candidates for the Switch Lites. I think I'll try a full tear-down and see if anything helps.
完成的
@davidartley do you have a multimeter ?
完成的
@davidartley in beep mode check the capacitors around the m92 chip to check for shorts, put the red probe on a ground like on top of the charge port and check the caps with the black probe, if any beep on both sides let me know
完成的
Excellent, thanks. I will try this at the weekend.
完成的
显示更多的4条评论
添加一条评论
@tech_ni i found four shorts on two separate points.
i have in ingress 0.14A at 5V
这个答案有帮助吗?
得分 0
3条评论:
I don't think they're shorts. I'm sure there should be continuity through those components.
完成的
since you only get 5v then its more than likely m92 thats the issue as it controls the 15v. remove it and check again
完成的
@nige56 there is only meant to be continuity through the coil not shorted, as the caps above m92 are marked red aswell
完成的
添加一条评论
添加你的答案
David Artley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 35
总计 292
