跳转到主内容
There are various different renditions of Saeco Minute coffee machines, also under the brand name Philips. All types start their Type Number with HD8xxx. Here you see a Philips HD8834.
7 个问题 查看全部
Where does the two pipes go from the water pump.
My coffee machine is tripping the earth all the time when making coffee and when I opened it, I saw two water pipes leaving the pump, one of them (clear one) is not connected to anywhere and tip is lying loose in the machine. Is this normal ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
See Saeco Minuto Pumpe tauschen, step 16. The pump ist connected top two pipes, one in (the clear one) and one out.
这个答案有帮助吗?
得分 0
2条评论:
Thank you. I meant the two pipes exiting the pump. One of them seems to be not connected to anywhere. I wonder if it is a pressure valve and the distal end is juts free/loose into the tray.
完成的
@Alp Numanoglu : can you take a photo? 在已经存在的问题里加入图片
完成的
添加一条评论
添加你的答案
Alp Numanoglu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 84
