跳转到主内容
Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
140 个问题 查看全部
No internal speakers, No charging port, No internal microphone.
My apple macbook retina 12 ( early 2016) seems to have an audio issue. The system does not recognize internal speakers and wont recognize headphones when plugged into the aux. The microphone also dosent work. The only way i can get it to give me audio is when i pair my airpods. is this a motherboard issue or perhaps just the audio board? thank you for reading
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like a failed Headphone Jack,
If the Headphone Jack Goes, It can cause some nasty problems!
Part: MacBook 12" Retina (Early 2015-2017) Audio Board
Guide: Retina MacBook 2016 Headphone Jack Replacement
MacBook 12" Retina (Early 2015-2017) Audio Board图片
产品
$39.99
这个答案有帮助吗?
得分 0
2条评论:
yea so I actually opened the laptop up after posting my question and found corrosion on both the audio board and the flex cable. I tried to clean it all of with 99% alchoal but i still dont get internal speakers.Do you think replacing the board and cable would get rid of my audio issue or would it require mainboard repair?
完成的
@Maikel Saba - I think replacing the audio board and cable would fix it.
完成的
添加一条评论
添加你的答案
Maikel Saba 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 21
