跳转到主内容
加入维修社区 - 创建账户
Stuck in a loop
Last night my phone suddenly restarted and gave me a notification saying it wasn't able to confirm that it is powered by a genuine Apple Battery, which is strange since I have never had this phone repaired or had anything changed. After a while, the phone started turning on and off around ever 5 minutes until it eventually just shut down for good. Currently, it is stuck on the apple logo and REFUSES to turn on... I can't even put it in recovery mode or anything to try to fix it. Help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Kalfhey,
It's going to be difficult to determine what's wrong without being able to power up the phone. A repair technician would probably open it up and start taking voltage and resistance measurements on the logic board to pinpoint the problem, but for us home do-it-yourselfers that's a bit beyond our comfort zone.
At this point the only clue we have is your indication that you got a battery warning on the original battery, so if it was my phone I would start there, by replacing the battery. They're not prohibitively expensive and one of the more common, straight-forward and well understood repairs, so it would make sense to try that as the first step in figuring out what's wrong with your phone.
Although you can find the battery cheaper on other sites such as eBay, Amazon or AliExpress, you can support iFixit's repair outreach by buying from them.
iPhone 12 mini Battery: Replacement Part / Repair Kit
And of course iFixit has you covered with a guide to show you step by step how to replace the battery.
iPhone 12 mini Battery Replacement - iFixit Repair Guide
Good luck; let us know how it goes.
Replace a 8.57 Wh battery compatible with iPhone 12 mini. 3.85 Volts (V).图片
产品
$39.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kalfhey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 92
