跳转到主内容
A1418/EMC3069/2017/3.0GHz四核心Intel Core i5、3.4GHz四核心Intel Core i5或3.6GHz四核心Intel Core i7处理器。于2017年6月8日发布。
Putting in a different display in an iMac systems shell
Hello Dan, I'm building a hack Apple Display and wondering if the screen of a imac 2017 will fit into the body of imac 2015? All other internal circuitry will be removed and replaced with a new display driver capable of delivering 5K to a 2017 screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@Chris Clausen - So your issued is strictly a mechanical one then. As you are not attempting to use the logic board.
I’ll be frank, I’ve never tried using the wrong display assembly as my goal was and still is keeping systems working as such I always put the correct display with the mating logic board.
So… maybe someone else has tried, sadly this is not a common idea.
这个答案有帮助吗?
得分 1
2条评论:
Fair enough, I'm sure it is a newer occurrence with the release of the display hardware drivers out of China. Appreciate you coming back to me. My investigations think they are the same shape screen. Cheers!
完成的
@Chris Clausen - Sorry I can’t offer a better answer, if you’re set don’t forget to score and accept the answer- Thanks!
完成的
添加一条评论
添加你的答案
Chris Clausen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 80
