跳转到主内容
Nothing Technology is a consumer technology company based out of London, England. They are responsible for Nothing Phone 1 and Nothing Ear 1.
6 个问题 查看全部
18650 batteries have gone absolute dead short
I have 2 18650 batteries for a vacuum cleaner, and they wouldn't charge. I took it apart and tested the cells, and 2 of them were completely dead, not even microvolts. I tested their resistance, it was 2Ω for one and 3Ω for the other. Idk what happened, if they over discharged or what, but not good.
Good side is: Yay! 4 more 18650 batteries for my collection!
P.S. Is there really a nothing phone???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
@anchefixes 18650 (and all lithium cell batteries), can have individual or multiple cells fail. That’s just how batteries are.
I have had success replacing individual cells, but it takes serious dismantling on the battery, and it’s not easy to get it correctly put back together. If you go the route of replacing one or more cells, be sure to use at least the same mAh rating, as “the chain is only as strong as it’s weakest link”.
PS! Yes,there is: Nothing
这个答案有帮助吗?
得分 2
添加一条评论
I would not replace only some cells in a stack. They are all old, even though some may not have failed yet. This means they have aged to a lower capacity. You will be creating a severe capacity mismatch. Depending on the protection provided, or not provided, by the battery management hardware/software, you will then experience overcharging, since the weak cells will charge to a higher voltage first, meaning the voltage applied across the pack will be higher for the weak cells, leading to ... fire and explosion. In discharge, the old cells will be depleted first, leading to critically low voltage for them, leading to copper deposition and subsequent ... fire and explosion.
Don't do it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anchevauls Walker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 49
